跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Both cameras not working
This iPhone has been dropped and has had a screen change. back camera was not touched, and was functional after drop and up to repair. front camera was functional after drop and up to repair. after repair both from and back cameras not displaying (black screen). i have checked both cables and have also changed front camera to test but no result. ideas ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
the problematic part is called U2301. U have to de solder chip and make a jumper between leg 1&2 (for fast repair -aprox 5 min)
Second method is change U2301 for brand new :
( http://www.ebay.com/itm/1PCS-U2301-Camer... ) -for example.
这个答案有帮助吗?
得分 3
添加一条评论
Yep. This is most likely the case. If the front panel connectors are unplugged with the battery plugged in or a metal prying tool used to unplug the front panel connectors there is a chance of accidentally shorting on or more components on the board. This U2301 ic component is located right near the front panel connector area on the logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Reboot Gozo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 8,431
