跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Touch Screen Dead Spots and LCD dim
My son dropped his phone in water and grabbed it right out. We set it to dry and it mostly works. The problem is some spots on the touch screen are unresponsive and the brightness of the screen is really dim until he is on it for awhile and the brightness comes back.
What do I need to replace???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hi,
First thing to change is the screen. You might have some damage on the motherboard, we could only help you with very HQ close-up pictures.
这个答案有帮助吗?
得分 0
添加一条评论
You should only need to replace the display assembly. Its a pretty cheap and easy fix on a 5S.
While you have the phone open, I would take a look at the battery, battery connector and any of the board you can see. Clean up whatever corrosion you see and inspect the battery for damage. If it was a quick drop, you might be ok.
If you still have issues after you replace the screen, then it will be time for some board level stuff. Especially watch out for quick draining battery, phone heating, etc.
这个答案有帮助吗?
得分 0
添加一条评论
Please click the link and watch then just tell him about your phone problem you may get a good solutions https://youtu.be/J_pcWczZik4
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SDC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 509
