跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Dualshock 4 controller will not charge.
So my controller is not charging no matter how many cables I try. So I decided to test the battery and see it that was it so I swap the batteries in my two controllers and not neither one will charger so I'm thinking it may be both the battery and charging port on the first controller because when I but the batteries back in the proper controller I get the second to charge. Both are still able to connect to the Ps4 so they're still somewhat good. I also want to add that it is a day one controller having this problems so that may be a factor.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
umm its a little tricky. id assume if you changed the battery and that didnt help, i would reccomend changing out the charge port/led circuit board. and if that doesnt get you fixed then it is the main motherboard in your controller.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FIREDEMON 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 966
