跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
The phone is not charging even though it shows the lightning bolt.
I have an iPhone 5c here in my shop.
It indicates the phone is charging but does not seem to ACTUALLY be charging.
I tested out a new battery and it was the same problem.
Swapped out the piece that has the Lightning port, headphones, speaker etc and inserted a new one. Same issue.
I looked online on this issue and saw a lot of iPhone 5s issues regarding a burned fuse but the fuse is of course, not on the 5c mobo.
Has anyone else experienced this and if so, were you able to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check the battery connector. Make sure its solid and not coming up from the board. Make sure there are no bent or missing pins. If that all looks good, Google the schematics for the 5S. Chances are that one of the charging components popped.
这个答案有帮助吗?
得分 1
1条评论:
checked them out, nothing is bent, all pins are there, and I tested it with a new battery and the original one, both in excellent condition. This is a 5c though, havent been able to find a schematic for that yet.
完成的
添加一条评论
添加你的答案
shinseraph22 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,102
