跳转到主内容
加入维修社区 - 创建账户
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
Can I modify Thunderbolt display to replace mindisplay with a USB-C?
Hi all,
I have a new Macbook but also a 2012 Thunderbolt display. The Macbook only has a USB-C port and I was wondering if anyone has come across people replacing the Thunderbolt display's Mini Display cable with a USB-C one.
Is this even possible?
Any Mini Display-to-USB-C adaptors were very quickly (and suspiciously...) discontinued shortly after they were released in 2015.
Any advice or info would be much appreciated.
Henry
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Do be clear here you want to use the Thunderbolt display with your MacBook, correct?
完成的
At present there is no adapter for the USB-C to Thunderbolt. and i do not believe there is any other way of doing it :(
完成的
添加一条评论
2个答案
最有帮助的答案
Sadly, there is no means to connect a new MacBook which has a USB-C port to a Thunderbolt display presently. Hopefully by the end of next month we might be offered an answer from Apple ;-}
这个答案有帮助吗?
得分 1
2条评论:
Just to keep this updated, there is now an adapter available from Apple - https://www.apple.com/uk/shop/product/MM...
完成的
添加一条评论
This is supposed to work, I have not tried it
https://www.nonda.co/products/hub-mini-u...
这个答案有帮助吗?
得分 0
2条评论:
Yep! I thought this hub would do it, sorry nope!
It's only DisplayPort compatible! Not Thunderbolt.
Note the compatibility line at the bottom 'Apple Cinema display only with Mini Display Port' no listing of the newer Thunderbolt display. I know I was hoping too ;-{
完成的
添加一条评论
添加你的答案
Henry Kirby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 2,109
