跳转到主内容
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
84 个问题 查看全部
Screen flickers and goes black except when minimum brightness is set
I love my 24" LED Cinema Display and it has been working great until a couple of months ago. I started noticed that it didn't turn on after sleep but I finally found that it started working again if I dimmed the screen a notch. That problem sort of increased and now it's only working when it's set to the minimum brightness. If I increase the brightness it starts to flicker and then after a couple of seconds it goes black.
Everything else works as expected (USB, Camera, Charger etc).
Anyone with and idea on how I can fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The backlight it most likely dead. Set the brightness to the maximum, then when it goes black, point a flashlight at the display and see if you can detect a picture. If so, the backlight is almost completely out the window and can only deliver a very little amount of light. A quick Google search comes back with many useful results here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 335
