跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Trackpad not working and erratic keyboard behavior
My laptop suddenly started to experience problems with the trackpad and keyboard for no apparent reason. At first the trackpad responded poorly and after just a few minutes it practically stopped working at all. Now the cursor cannot be moved and clicking by tapping does not do anything. However, clicking seems to work sometimes when actually pressing the touchpad, which gives the "click" sound. Additionally, sometimes the trackpad is not found at all in system preferences.
The keyboard problems started at the same time. The keyboard often doesn't momentarily (for 1-2 seconds) register keypresses and sometimes the keypresses get repeated numerous times although I only press them once . This seems to affect all the keys, not just a certain part of the keyboard.
I've tried resetting SMC, NVRAM, deleting preference files and reinstalling OSX but they did not help. I also opened the laptop and checked that the trackpad/keyboard power connectors had not become loose. I also inspected the batteries and they did not seems to be bulged. Any ideas where to continue troubleshooting?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
Did you spill any liquid onto it? May be someone did without you knowing?
完成的
Yes, I have previously spilled some very small amounts (maybe a few drops that were shortly wiped off ) of water on the keyboard and/or trackpad.
完成的
When was that?
Trackpad and keyboard are channeled to the logic board through the same board connector. If it was liquid damaged earlier, it started corroding and now reached the point of failure. Tear your computer down again and look for traces of corrosion.
完成的
It has happened several times in the past and the last time was maybe a few days ago. The spillages have always been miniscule and there never was any immediate damage so I dismissed them although they seem to be the most likely reason that could have caused this. I'll try to look for the corrosion traces next. Thanks for the help.
完成的
If you find something and not sure how to handle it, report back and we'll guide you. Post pictures of affected areas.
完成的
添加一条评论
2个答案
My best bet is it's your logic board. I've had issues with the logic board affecting other parts in the past.. this is really the only place you could remotely do any such test for free..Hardware test
这个答案有帮助吗?
得分 0
添加一条评论
I know its an old post but im experiencing exactly the same issue with my Macbook Pro Retina 2014 for few days.
I was at a Genius Bar this morning, he said me on this model we have to change everything because "all is linked together" (i bet that all is linked together, it's a computer you know, but come on...) and told me it will be a 650$ fix. I said no, i don't want to change the top-case/battery for now, and without it the price has well decreased, just 120$ to change the keyboard / trackpad. They kept my computer so I will give some news in few days to see what is going on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
leinonen305 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,367
