跳转到主内容
Released 2016, January, identified by model number K430T. The type of display is IPS LCD capacitive touchscreen, 16M colors and a 13-megapixel camera.
40 个问题 查看全部
Power button failing when in the dark?
Just got a LG K10, for some reason if I'm in a dark area the power button/volume buttons become unresponsive. This issue does not exist in well lit environments. Anyone else experiencing this, or does anyone know why this might happen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I started having this issue ever since I got my screen replaced. I think it's some kind of hardware issue. If I'm in the dark and this happens it's because I have the brightness all the way up. When the brightness is on 0% and I'm in the dark I don't have this issue. So try lowering your brightness. Glad I'm not the only one with this issue
完成的
添加一条评论
5个答案
已选择的解决方案
Performed a factory reset last night, this did not resolve this issue. I will say though I did a little more trouble shooting and I might have figured it out.
I recently put a protective case on the phone that has a tempered glass screen protector. It could be that the tempered glass is somehow triggering the proximity sensor, making the phone think it's next to someone's head. Then with that sensor tripped and little to no light detected the phone thinks it's best to not turn of the screen.
这个答案有帮助吗?
得分 2
添加一条评论
The light sensors may trigger your device .
So the best solution for you before you do anything else,is to factory reset your phone
这个答案有帮助吗?
得分 0
1条评论:
So ,you have figured it out .Great ,happy for you :D
完成的
添加一条评论
I have the same issue.. Im reading up on this... has to do with the tempered glass everybody recommends remove the tempered glass find a tempered glass with cut out for the sensor by the camera
这个答案有帮助吗?
得分 0
添加一条评论
This is bs my screen just blackens when the proximity cencor is covered where do i trun this shot of?
这个答案有帮助吗?
得分 0
添加一条评论
When in the dark area my phone swicth fail to come
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gage 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 13
总计 2,596
