跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Why can't you buy a 6s digitizer without the LCD?
Hello. I'm new to repairing phones, so this may be a silly question, but why is it so difficult to buy the iPhone 6s digitizer without the LCD?
I've replaced a broken screen on an old iPhone 3GS, and the replacement digitizer I bought didn't have the LCD attached, I had to transfer it from the old display.
I would imagine that a digitizer without an LCD would be substantially cheaper than one with the LCD, so why can't I find any? Is it impossible to remove the LCD in the 6s? Is there a time period after a new iPhone is released in which you can't buy the digitizer separately? Or is there some other reason?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
There is no digitizer, the touch function is built into the LCD panel.
The front glass is just glass, and it is directly bonded onto the LCD. It's not like iPhone 3GS that there are separate pieces. Unless you have the expensive equipment to peel the glass off and risk cracking the LCD every time, it is not possible to separate them.
这个答案有帮助吗?
得分 1
添加一条评论
While Tom is basically right, he's not technically right.
There is a separate digitizer for the iPhone 6s. However, its bonded onto the LCD. You can peel it off if you try hard enough. However, the problem is getting a new digitizer on the LCD. The digi is bonded onto the LCD. It is possible that you could use some sort of heat stamping method to get the new digi on, but you have no way of getting it lined up. The process used to line up and bond the digi to the LCD involves a machine that uses x-rays and sometimes lasers to line everything up down to the fraction of a mm. It then bonds it in a special process.
So the quick answer is yes, you could save yourself the extra $30 that a screen with a digi attached would cost. But it would cost about $5,000 in machinery and I don't know how long in time to acquire the skill to get things right.
这个答案有帮助吗?
得分 0
2条评论:
Well, iphone 4 and 4s has this kind of 3-layer design, LCD (display cable attached)+digitizer (touch cable attached)+front glass. Since iphone 5, the standalone digitizer is elimitated, the touch sensors are built right into the LCD, there is only LCD+glass.
完成的
take a look at an iPhone 5+ LCD. You'll see there is one cable for digi, one for LCD. Follow the digi cable back to the LCD and you can peel that connector off. Grab a razor and you can peel the digi off.
Like I said...you were right. But sometimes when troubleshooting a touch issue, its important to know that the LCD and digi are 2 different things and can malfunction independent of each other.
完成的
添加一条评论
Everyone's right except I have done this repair and replaced glass only...while it wasn't the easiest thing I heated it up and used a super thin metal wire and fishing line to separate the glass from the glue then I used one of theseHere= to line the new glass up the apply LOCA UV glue which has to be cured by uv light but once cured your ready to install So THERE IS NO NEED FOR $5000 IN EQUIPMENT
这个答案有帮助吗?
得分 0
1条评论:
Is digitizer not screen glass both not same thing dude.
完成的
添加一条评论
I'm guessing its because of the 3D Touch layer on the iPhone 6s.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Michael Sligo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 396
