Computer won't turn on after replacing memory and battery
After replacing the battery and the memory my computer won't turn on. When I went ahead and put the old battery and memory in it also wouldn't turn on. I feel like I might have done something during the installation process that has caused the computer to not work. I believe I might have switched out the ram while the new battery might have been plugged in and if that's the case and I shorted it, what can be done now?
Any tips are appreciated
7条评论
Does it draw power from the charger?
由 echow2001 完成的
When I plug the charger I see a green light. I also see a green light if I have the battery removed. Hope this answer helps.
由 khaledatti 完成的
does the fan spin at all?
由 echow2001 完成的
You may want to check out Louis Rossmann on Youtube with his videos regarding the onewire circuit and power rails.
由 echow2001 完成的
ok try taking out the ram and battery and disconecct power adapter, Now press the power button keeping it pressed for 1 min the put it back togerther and try again. Aso have a look at the ram slot to make sure you have not damaged the slot/pins.
由 Gary 完成的
显示更多的2条评论
