跳转到主内容
加入维修社区 - 创建账户
Computer won't turn on after replacing memory and battery
After replacing the battery and the memory my computer won't turn on. When I went ahead and put the old battery and memory in it also wouldn't turn on. I feel like I might have done something during the installation process that has caused the computer to not work. I believe I might have switched out the ram while the new battery might have been plugged in and if that's the case and I shorted it, what can be done now?
Any tips are appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Does it draw power from the charger?
完成的
When I plug the charger I see a green light. I also see a green light if I have the battery removed. Hope this answer helps.
完成的
does the fan spin at all?
完成的
You may want to check out Louis Rossmann on Youtube with his videos regarding the onewire circuit and power rails.
完成的
ok try taking out the ram and battery and disconecct power adapter, Now press the power button keeping it pressed for 1 min the put it back togerther and try again. Aso have a look at the ram slot to make sure you have not damaged the slot/pins.
完成的
显示更多的2条评论
添加一条评论
2个答案
最有帮助的答案
这个答案有帮助吗?
得分 2
1条评论:
check my question out gary.
完成的
添加一条评论
Alright I went ahead and tried the reset for 1 minute and I had no luck. There has been some weird things happening and I need to describe them.
First off when I remove the battery and power cycle the MBP by holding for 10 seconds plug it in and then continue holding for 10 and then press the power button again it turns on. It starts and connects to the internet and everything. This is without a battery. When I went to overview though it still reads the memory as 4gb instead of the new 16gb. I tried shutting down and starting with the battery in it this time and it didn't work. I even tried an SMC reset and all that fancy shmancy stuff.
Then I was kind of getting upset so I powercycled it again and while it was on and working I plugged the new battery in. All of a sudden the fan sped up and was making much more noise. The computer obviously wasn't detecting the battery and said the charge was at 0%. Also in the same fashion there wasn't a battery indicator at the top menu bar beside the WIFI. I decided to take things a step forward and unplug the charger, to see if the battery was working. Because if the computer continued to run on the battery then there has to be some dumb miscommunication or something stupid going on. When I unplugged the AC adapter viola, the computer stayed on with the battery plugged in. Now the crazy part is that I shut it down and restarted it almost 3-4 times and it was fully running on the battery. Yet it still didn't detect the ram and also continued to say 0% charge.
let me know what you think because I'm a PC guy, this is for my wife and its getting crazy up in here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
khaledatti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 156
