跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Tools to repair systemboard.
Hi!
Today I read a very good text from JULIA BLUFF talking about iPhone 6 Plus touch problems.
My question is:
Does anyone knows what tools Jessa use to repair those boards? Like microscope brand and model, solder iron brand and model, hot air station brand and model?
Regards!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi andre, at the bottom of the description of this video https://www.youtube.com/watch?v=-PaxtbIL... you can see all the equipment.
这个答案有帮助吗?
得分 1
2条评论:
Amscope is pretty much it for decent scopes. There are more than a few models but Amscope is what most use.
She uses Hakko solder and hot air tools. They are good but I use X-Tronic since they are about half the price of Hakko. Weller makes good stuff, Aoyue has a strong following as well.
I also highly recommend the iPhone micro soldering test kit from iFixit. Tons of tiny pieces to play around with and not risk frying something expensive.
完成的
Thank you! It help me a lot! I will start buying Amscope and then I will see hot air tools since those tools are all very expensive. Regards!
完成的
添加一条评论
Always practice on a broken logicboard as when i 1st started i had a cheap air gun and cheap soldering gun and i ended up burning off the pads behind the chip connectors and that was down to the heat so i got all the proper equipment then practiced on a smd diy clock that i built then onto broken logicboards and now im loving it but its all down to practice, good luck
这个答案有帮助吗?
得分 1
1条评论:
You are right. Practice is the most important thing. In second place good tools. But I see that Jessa uses a USD 2000+ hot air station! I can't afford it! But I guess It can be done with not so expensive tools.
完成的
添加一条评论
添加你的答案
andre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 94
