跳转到主内容
The Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is designed as an all purpose camera that is waterproof, shockproof, and freeze-proof.
17 个问题 查看全部
My front cover glass broke
Can I replace the front cover?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
My camera broke as well...
I pulled out the silver ring that surrounded the original broken glass (it is easy to remove using a small pliers), cleaned all the broken glass pieces and ordered a flat glass watch crystal diameter 29mm Thick 1mm on aliexpress
Once it arrives i believe I can glue all the parts together again, almost like the original camera.
(search for "flat glass watch crystal diameter 29mm thick 1mm" on aliexpress, costs less than 2 dollars)
这个答案有帮助吗?
得分 0
1条评论:
Hi,
I'm curious to know if that worked and if the camera kept being waterproof. I thought about replacing the whole front cover but I don't find that part anywhere...
完成的
添加一条评论
添加你的答案
alexander288 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 175
