跳转到主内容
HP's 7" tablet released in April 2013 with a few upgrades over the first iterations. Repair for this device is similar to that of other Android tablets, requiring only screwdrivers and a prying tool. Available as 8 or 16 GB / Red or Silver.
Power on/off button doesn't work
Hi i have HP Slate7, which is working fine just the power button is not doing the job of turning on or off. how can we fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You may simply be looking at a worn-out power button. iFixIt has a repair guide all about fixing this exact issue. Take a look-see at this HP Slate 7 4601 Front Screen Replacement repair guide for the how-to. Or, if it's an HP Slate 7 Plus, it may be a bit tougher to fix however, here's a post about a possibly similar issue: My tablet can't be turned on even after charged.
If those links do not help, please provide more detail about your particular power button issue. For instance...
  • Can you get it to work sometimes but not others?
  • When the screen turns on after rebooting the tablet, can you tell how much battery is left?
  • Does the power button seem loose and/or can you wiggle the button more-so than normal?
Good luck,
_rs
这个答案有帮助吗?
得分 0
1条评论:
My HP slate 7 beats audio. Won't turn off. My power button is missing. How do I fix it. I need to reset it. Don't know password.
完成的
添加一条评论
添加你的答案
sophie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 945
