跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Battery Replacement Dimmed LCD Backlight
I replaced the battery from my iPad mini and the LCD backlight got really dimmed. I also did it on another iPad and same thing happened.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did you take care to not reseat any front panel connectors when battery is plugged in? If not this may be a backlight IC (forgot what it was really called) issue.
这个答案有帮助吗?
得分 1
4条评论:
What do you mean by front panel?
完成的
I didn't touch those.
完成的
I meant the LCD and Digitizer / Touch screen connector that plugs into the logic board. Make sure that you do not unplug or plug those in while the battery is connected to the logic board or you may have issues related to backlight.
完成的
Nah, I didn't touch those.
完成的
添加一条评论
添加你的答案
Abraham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 117
