跳转到主内容
My phone is not able to make or receive calls, why?
But Sim Network Showing Properly.
Despite being connected to the network, I am unable to make calls or receive calls on my HTC Desire 816 Dual Sim.
When I try to make a call, the phone immediately shows "call failed" even without any ringing.
When others call my number, they report that my phone is 'disconnected or Out of coverage area'.
What is wrong? How can I correct this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论:
Hi,
Has the phone worked properly before? Have you tried your SIM in another network compatible phone to prove that it works? Have you tried another known working network compatible SIM in your phone?
完成的
jayeff Thanks
same SIM used another phone working fine.....and any other SIM used same Issue.
完成的
Hi, Has the phone worked properly before? Have you tried the other SIM slot (use network manager to turn it on) and see if it works?
完成的
Was this problem solved? I am facing same issue. Please advise on any solution
完成的
添加一条评论
1个答案
I had this happen one time. I accidentally put my phone on airplane mode. When your phone is in airplane mode your wifi and phone signal are disabled even though they are connected. Press and hold your menu button. A power off, airplane mode, and silent buttons may come up. Tap or uncheck airplane mode. If it is on, this should turn it off. If this does not work go to settings ( the little gear). Tap wifi and you should see airplane mode. Uncheck it . If this does not work, while still in settings and wifi look the button more . Airplane mode will be under it. Uncheck it.
I hope this works for you. There is a short untube video that may help. I looked up how do you reset airplane mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manoj Vinchu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,461
