跳转到主内容
Released 2014, October; Android 0S, v4.4.4, up to v5.1; 32/64GB storage and exclusive to Verizon Wireless.
42 个问题 查看全部
Why Won't it come on after repair?
Three weeks ago, my phone randomly stopped working. It was minding it's on business sitting in a corner and all of a sudden the screen stayed black. I could hear the notifications but it wouldn't turn on(the screen). Then I charged it and when I would try to power it on, it made the power up sound and vibration but didn't light up. No lights would light up. I was told it was my LCD so I ordered a new part, replaced it and made sure the ribbon cable was secured and I still got the same result. Now if I try to turn it on, the power up sound keeps replaying every 10 seconds til it dies, or i disconnect the battery, still without and sign of life in the new screen/LCD or even notification lights. What could be the problem?
NOTE: It was in some heat that day, but it's always hot here. The screen had a crack and some small glass chips that had fallen out from the top left corner from a previous drop months ago, but other than that it was perfectly fine.
Thanks so much for any advice!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
That happened to me and I figured out if u just leave it for a couple of days then put it in charge and it should automatically have the charging sign then the apple logo and it should turn on
这个答案有帮助吗?
得分 1
3条评论:
Thanks @alberty Should I leave it on the charger all day for a couple days? I left it on last night
完成的
No cause I tried that and it didn't work so I left alone and I tried turning it on everyday
完成的
And also it happened more than once so I think it might be that the phones been used for a long time so that it's like out of use
完成的
添加一条评论
It’s possible the display connector isn’t properly seated. I’ve had that happen or just a blinking LED notification light would come on. After reopening the phone and disconnect then reconnect the cables everything worked fine. It’s also possible the new replacement display is defective.
By the way, if I turn on an Android phone and the Apple logo shows up, I’m droppin’ off the grid.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mesha 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 482
