跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Audio changes volume when recording video
Sometimes when I record a video on my iPhone, when I am speaking, the audio will start out very hot and then sound like it "compresses" everything causing the audio level to be drastically different and drop. Almost as if it is trying to reduce background noise. Has anyone else experienced this issue or know how to fix it?
When I try the same thing on my old iPhone 5s, it doesn't do this and keeps the same volume level throughout the video.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I have the same problem and am searching for a solution. Did you have any luck? Do you have any recommendation?
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue all the time. Then I started recording voice through external mic (in headphones or audio splitter), but now somehow I damaged also audio routing… and i think I’ve got short between audio lines…
However, problem of suppression in video recording is also annoying for me…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 376
