How do I stop my phone from glitching
My phone keeps frezzing and glitchng fro m app to app. It makes calls, frezzes.
There could be many reason for that:
The CPU speed of your device is 1.2GHz meaning it can process apps at a decent speed, but when multiple apps demand the CPUs processing at the same time, that's when your phone will throttle and freeze...
[] Try closing all other apps including games and browsers.
[] Download and run CCcleaner for andoid:
https://play.google.com/store/apps/detai...
[] run only 2 or 3 apps at the same time (remember that your android device is already runs a "few" at the background. so adding more applications will surely bog it down.
You might want to consider devices with higher CPU speed in the future (do not mind marketing gimmicks like quad core CPU, octacore cpu, for most application what really matters is the CPU speed)
hope this helps
这个答案有帮助吗?
I had his problem I think it’s to do with water damage or any other liquids but I left my phone without connecting it to any electric and let it dry out over night and it’s fine now
这个答案有帮助吗?
My s5 screen glitches out so bad it mixes up the screen .. sends the key pad up the to the top. Scrambles word and some wierd squares start to look like snow on a TV that is on a bad channel please please help I'm on disability and I can't afford a new phone itvwas find when I got it a month ago from a friend I've never dropped it I'm scared I won't have a phone soon I'm so broke and this is my only way to conect please help
my phone is glitching so much that i cant use it and it will automatically go into an app i did not press on and when i go to my display things i didn’t touch go on and off it happend once and and then stopped it was over christmas and lasted until acouple of days before i went back to school. PLEASE HELP
这个答案有帮助吗?
it was with my zte zmax pro
My phone keeps going from app to app without me touching it. It also turns my brightness up and down, turns on airplane mode, turns my location off, turns flashlight on, and the lock/home screen moves…
这个答案有帮助吗?
I have a zte, while it charging, some times it calls and text, people.
If I am talking to someone on the phone, it will call other person while I am talking to them. I solve that by all ways using the speaker on which I do not like, mine all so goes in to airplane mode, my friend has some of the same problem with zte
这个答案有帮助吗?
Pls explain and clear this problem
This started a few days ago and is getting worse
I need the flicking to s
这个答案有帮助吗?
turn the phone off and when you hold the power button, hold the up volume button and select reboot.
It looks like the ZTE brand is crap, pure and simple and we who can't afford an iPhone or S10 will just have to live with this junk, ugh
这个答案有帮助吗?
How to stop glitches and freeze and and add during games and when I'm watching videos enterapting
这个答案有帮助吗?
这个答案有帮助吗?
Yes I said that
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 15,562
