跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
TouchID and Home Button not working after replacement
Hi,
I order from a seller on eBay a iPad Mini 4 LCD/Touch replacement. I saw that it has to desolder and solder again a flex that connects the home button to the assembly.
After the replacement and transfer for this flex the home button will not work, but if I solder it again to the broken one. It will work flawless. any one had encountered this issue?
I test the same procedure on 3 different replacement LCD/Touch assembly and in neither will work, only on the original broken one.
Any help will be thanked!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The home flex cable may be torn??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 833
