跳转到主内容
The Samsung Epic 4G is the first US released version of Samsung's Galaxy S II. Also known as the Samsung Galaxy S II Epic 4G Touch.
16 个问题 查看全部
Galaxy S2 turns on for a few seconds then turns off.
I have a Samsung Galaxy S2 Epic 4G, and the problem is that when I try to boot it on battery, it turns on for a few seconds, and then turns off. But it works fine when on charge. Do I need to get a new battery? Or is there something else wrong that I need to replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Daemeon,
Check the battery's physical appearance whether it swollen or not. if it is swollen just disposed the battery proper way & buy a new battery otherwise clean the battery terminals and charge the battery at least 15mins. hope you have good result :-)
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
I would definitely start off by getting a replacement battery. The symptoms you are describing point to most likely a faulty battery.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Daemeon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 396
