跳转到主内容
Repair guides and support for your LG TV.
1342 个问题 查看全部
HDMI input on my 4k LG not working
LG flat screen 55uf645
My inputs
Is not working it said check I puts
Update (08/30/2016)
Yes tried all HDMI ports 4k only works on hdmi1
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi,
Can you prove that the device(s) that you wish to connect to your TV using a HDMI connection are working via HDMI by connecting to another TV? Have you tried using a different HDMI cable? have you tried all the HDMI connections on your TV?
完成的
yes used different TV, New HDMI cable, tries ALL three HDMI ports
完成的
can HDMI board be replaced
完成的
添加一条评论
2个答案
最有帮助的答案
Try removing all HDMI cables and then "remove" the power cord for about 10 minutes (powering off is not sufficient ). Then Plug in the power cord, then one HDMI cable and try your device that way.
Also, something to note there is a known flaw with these tv's that cause a spike on the motherboard that cause the HDMI ports to stop working altogether.
http://www.lg.com/us/tvs/lg-55UF6450-4k-...
Look under ratings and reviews.
Hopefully the reset will get you backup and running though.
The board replacement is not hard either though.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, the powering off for a few mins worked.
完成的
添加一条评论
The solution sounds crazy but remove the main board and bake it in the oven to allow the weak solder joints to reflow, it will normally last about a year or two depending on use, when they go out again, repeat.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
red6424 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 33,729
