iPhone 6 plus dead
Hello,
I'm trying to repair an iPhone 6 plus that's just completely dead. Tried replacing the screen and battery from a working phone but it doesn't turn on. Could it be the U2 1610 IC chip?
Update (08/22/2016)
The phone is connecting to iTunes now (screen stays dead however) and it's in recovery mode but when i try to restore it, just before it finishes i get an error saying it got disconnected.
Update (08/24/2016)
I had a working iPhone from which i was using parts to test on the dead iPhone. Now i assembled the working one again and after turning it on, the screen is just full of lines but it worked completely fine before? Could the screen have become damaged or is it the connector on the logic board or could it be the touch IC chip?
Its possible that its the U2. What is the device's history? Did you buy it dead? Did it have a drop or water damage? What happens when you connect the phone to a computer? What happens when you do a hard reset?
由 Josh W 完成的
It is completely dead, doesn't even heat up when i charge it. And the computer doesn't recognize it either. And i have no idea what the history is of the phone, my customer told me that he bought it dead.
由 Ben 完成的
NO, its not U2
由 Buddhika Mahesh 完成的
U2 tristar IC is charging chip right? With the issue diagnosed as this, I don't think it's the U2 and more likely so the power management chip (forgotten the name for it).
Because if it was really just U2 the phone should be able to turn on with a known working iPhone 6 plus battery.
由 Ben 完成的
I tried to connect it to itunes today again and now it recognized and it's in recovery mode. The screen however stays completely dead.
由 Ben 完成的
显示更多的2条评论
