跳转到主内容
A revision to the original PSP 300x, released in 2010. Repair is just as easy.
10 个问题 查看全部
Psp 300x Backlight Fuse
Hi Guys!
I have my old PSP 3001, I drop it on the floor. Still turn On and Off, but with out image...
I replacentment the LCD, but still not working.
So I found out that is a BACKLIGHT FUSE,
Please some one tell me
"WHERE IS THE BACKLIGHT FUSE"?
I am tired to find out and get no result!
Thanks all guys who read and help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
There is only a backlight fuse. There is no screen fuse. There is either a problem with the screen, or one of the components on the motherboard. Probably the IC that is in charge of video.
这个答案有帮助吗?
得分 0
添加一条评论
Try checking component ic4104. That's the backlight driver and is located in the 11,C quadrant of side A on a TA-085 v1 board. The part number is TB62752BFUG. Test each connected capacitor to ground in continuity mode with a basic multimeter for a short. If one or more of the capacitors are shorted remove those and check the pads where the capacitors were. If there's still a short on both pads where the capacitors were then put back the original ones. Odds are if there's a short to ground but doesn't go away when you remove the capacitors then TB62752BFUG needs to be replaced.
PSP 2k Schematics (~95% 3k)
https://gamingdoc.org/technical-document...
TB62752BFUG Datasheet
https://www.mouser.com/datasheet/2/408/T...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josemar Pereira 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 12
总计 367
