跳转到主内容
加入维修社区 - 创建账户
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
iPad won't turn on at all
I replaced the digitizer screen as well as the wifi antenna and when I plugged it in... nothing. Won't come on at all. When I was in the process of replacing parts I plugged it in (not while I was doing the work) so that when I was done it would be charged enough to check things out and see if everything worked. When I first plugged in the power I noticed that it was kind of flashing, faint, more like a flash from a TV trying to come in.
So I unplugged it and figured that I could just charge it when I was almost done. That didn't work. I don't even get the flash any more. This all began because of a broken digitizer screen which I unfortunately have replaced twice over time
Any thoughts?.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try to hook it up to power and see if its just your backlight. shine a light where the apple logo should be and check if you can faintly see it, also have you tried connecting it to iTunes?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Susie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 122
