跳转到主内容
A splash-proof, portable Bluetooth speaker from JBL, released September 2015.
29 个问题 查看全部
JBL Connect drawing App malfunctions, no effects
The drawing function (last one on the right) in the Android JBL CONNECT App V 1.7.3.4 doesn't produce any drawings on the speaker, the only effect after drawing eg "Hi" on the screen is that the lights go off and a 2cm orange stripe appears in the rear part on the bottom... Very disappointing ...and I already updated it to the newest version from Aug 2016. Any idea what's wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hello, I have the same problem with the drawing function, and I also have a problem with the JBL Prism color sensor lens that doesn't detect the color I'm pointing. Do you have the same issue ? And did you find a solution ?
Thank you in advance.
这个答案有帮助吗?
得分 1
1条评论:
The drawing function just sucks because I have the same issues. However , the color selection works great. What you need to do is place the lense directly on the object or color you want. Cut off any outside lighting to the object. I mean really push the lense against it. Then press the button. That works 99% of the time for me.
完成的
添加一条评论
添加你的答案
Mat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 538
