跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
How do I replace the trackpad?
Looking for step by step instructions on how to replace the trackpad. I will be purchasing a replacement trackpad for my 2009 MacBook Pro. I'm wondering if the instructions come with it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
No, their won't be any instruction sheet with the part. But, we have you covered here!
OK, You'll need to follow two different guides as we don't have one guide that covers the whole procedure. Follow this guide here first: MacBook Pro 15" Unibody Mid 2009 Battery Replacement This will get you to the trackpad which is just underneath it. Then follow this guide: MacBook Pro 15" Unibody Early 2011 Trackpad Replacement. Jump to Step17 to disconnect the ribbon cable. Then picking things up from Step 26. You'll note in this guide the logic board was removed to gain access to the cover sheet over the trackpad cable here we'll carefully lift it from the side enough so we can sneak the cable out. Just follow the guide in the reverse order to put things back.
MacBook Pro 15" Unibody Mid 2009 电池图片
指南
2019年中期 MacBook Pro 15" 一体化机电池更换
难度:
中等
15 - 30 minutes
MacBook Pro 15" Unibody Early 2011 Trackpad图片
指南
难度:
中等
45 minutes - 2 hours
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Laura Eberhard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 214
