跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Can the A5 chip be upgraded to a A8
Can the A5 chip be upgraded to a A8 If not is there any chip that will work
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It's worth a try il let y'all know if it's possible
完成的
添加一条评论
3个答案
已选择的解决方案
I believe that in life you can do everything with money, and the right skills, but this deep change does not believe it is possible for a user with an average dismantling experience. I'm sorry but I really believe that it is not possible
这个答案有帮助吗?
得分 2
2条评论:
Just not possible! The chips I/O are very different.
完成的
It won't be cost effective at all.
完成的
添加一条评论
最有帮助的答案
That would involve redesigning the PCB and the OS, costs about several million dollars at least.
这个答案有帮助吗?
得分 5
1条评论:
Chump change! ;-}
完成的
添加一条评论
no doesn't seem possible, the money putting in changing it can get you the latest phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wayne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
