跳转到主内容
加入维修社区 - 创建账户
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
What is the problem
I left the iPad for three months at lower than critical charge. It won't turn on now. Tried charging but did not work. Connects to iTunes. ITunes says iPad in recovery mode. Need to be restored. Downloads the software and does nothing. May be due to pass code. Thought the battery died. Opened it successfuly but battery seems alright.. Can't figure out the exact problem before I buy the parts. Any help will b appreciated... Thanks in advance...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like its in DFU mode. Try holding the power and home button for 10 seconds to do a hard reboot. If this doesnt, work try charging it for a while. Im not sure who long you tried to charge it, but I've had to leave iPads for close to an hour before to get them charged up enough.
这个答案有帮助吗?
得分 1
3条评论:
I tried holding the home and lock buttons together... Didn't work.. Left it all night on charging.. Still did not work..
完成的
Is there a way to test the LCD alone.
完成的
Not that I know of. Since you opened it, I know you reseated the cables etc. The battery could be bad even though it looks fine. I have also had an iPad 2 in the past that flat out died and nothing I did brought it back. There is a charging IC chip of some sort that can go bad, but I dont do board level repairs, so I didnt pursue that troubleshooting step.
完成的
添加一条评论
添加你的答案
Ashish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 100
