跳转到主内容
My MB Pro not power on but the adapter LED illuminates?
My MBPro will not respond to the power button at all. No lights, no sounds. Simply an unlit screen. The power adapter LED, however, appears to be working normally. It begins green and then turns to orange to suggest it is charging the battery.
Two months ago the battery indicator indicated I should 'service battery'. Could a dead or otherwise problematic battery be the cause?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Most likely yes!
Sadly the way to tell was using the built-in battery tested the older models had (your's doesn't have one).
If the testers LED were green then we know the battery was good and the logic board had a problem. Here you could have either a bad battery or the charging logic on the logic board was damaged. Do make sure your MagSafe charger cord is not damaged often I see this as the root cause of the damage within the system.
Given the age of the system I would recommend visiting an Apple Store to see what they say.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Omar McDoom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 129
