跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone 5C Apple logo flashing? HELP
Hello, When I put the charger on my iPhone the apple logo flashes and when I disconnect charger the logo stop flashing and iPhone wont turn on. I tried to hold the home button and lock screen button the iTunes logo appears but when i disconnect the charger to plug to laptop for restoring through iTunes the phone goes off again. I can repair phone by myself just i cant figure out the problem. Please help me!!
Update (09/08/2016)
I think it might need to replace the battery, cause I putted phone for charging for about 2 - 3 hours but later I disassembled it and reassembled it to make sure everything was on right place and connected well and when I turned my iPhone it displayed the symbol of not battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
It sounds like you have a bad power IC chip that needs to be replaced. For me, it's not an easy repair because it involves soldering. However, there are services you can purchase on eBay that do this for around 40 bucks. That's definitely worth it and I have had this done for customers in the past.
这个答案有帮助吗?
得分 1
添加一条评论
Hi. If you have tried restoring it (and that has not worked) try entering your phone into DFU Mode (simply Google "DFU Mode Apple" and follow the instructions). This will totally reset your phone, erasing all of your data. It will also remove the software and reinstall it. If this does not work, you can try contacting Apple for further support.
这个答案有帮助吗?
得分 0
2条评论:
I tried it, but it says error 2009, I tried some tutorial to fix it but It doesn't work. It was working 1 month ago, but than i brought a digitizer and it was faulty I had to return which took 1 month and after that when I got a new one, that's when It made that problem.
完成的
Beyond that, I don't know. Somethings may have occurred to the iPhone whilst the digitalizer was replaced. Or it may be that the error was caused by your iTunes on the computer. If it's not updated to the latest version, update and try again.
完成的
添加一条评论
I fixed it, it was the battery, I ordered a new one and it is working fine now
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mirza Zaheer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,186
