跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
iPhone 5C Screen wont fit? HELP
Hello, I recently changed the back of my iPhone 5C and replaced the digitizer, but now the screen doesn't fit on the left side, I tried to push it but it wont. When I remove battery it does fit, but with battery is about 2 mm up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be a manufacturing defect with the back as these are more than likely all aftermarket backs. I highly doubt it's fully original unless it's pulled from a new 5c. I would check to make sure the battery is sitting flush in the phone. When you pry the battery out it can warp and get lumps in it. I'd put the battery on a hard flat surface and use your hands to flatten it out. Dont use excessive force, because you may damage it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mirza Zaheer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 86
