跳转到主内容
Model A1320 / 8 or 16 GB capacity
157 个问题 查看全部
Drove over my ipod nano 5th generation and broke out front glass
I accidently drove over my 5th generation nano and broke the glass out of it. What can I do to have it repaired? Is it possible to have the entire outside case replaced including the glass screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
8个答案
最有帮助的答案
http://shop.ebay.com/?_from=R40&_trksid=...
A cheap option here some Chinese company offering the glass for less then 5$ check it out.
The glass isn't the easiest to replace on the nano 5th gen. Check it out on ifixit guides or google.
这个答案有帮助吗?
得分 1
5条评论:
"some chinese company off ebay" does not sound very reliable. I'd stick with the nice iFixit part I suggested, or a part from some other reputable source, such as OWC, Newegg, or MacMall
完成的
Ah but the part you linked to was the LCD for the nano NOT the glass. Additionally I have not seen the glass on ifixit which was why I refered to ebay. Also none of the online retailers mentioned carry ANY repair parts and only sell whole products. However a 5$ investment in the ONLY glass that is readily availible on the internet is a good bet, "Chinese and cheap" or not. Also it is glass... theres not much that could be defective with a piece of glass (Not liable to explode)Besides its only 5$
完成的
I have confirmed niether ifixit nor any of the on line retailers carry the glass. Besides Karen Cattell clearly stated she need the glass not the LCD which ifixit supplies.
完成的
A display consists of LCD+glass.
完成的
the original poster mentioned "front glass" in the title of this question, so I assume she only means the front piece and not the LCD display underneath. in this model iPod, they are separate.
完成的
添加一条评论
You can get a new display here.
这个答案有帮助吗?
得分 0
4条评论:
Should be downvoted, this is the wrong part...
完成的
Actually not...
完成的
@Liam Spiers, Do not expect someone else to downvote! If you think this answer is wrong (is it correct, by the way), I suggest you save for 100 rep and do it yourself. Also, give a little respect to those you have many times your reputation.
完成的
Thanks QE
完成的
添加一条评论
It still all works but the glass cover is broken. I just need the glass cover. the LCD screen is just fine.
这个答案有帮助吗?
得分 0
添加一条评论
Where can i get a glass? I dropped mine and iy shattered, need to replace the glass.
这个答案有帮助吗?
得分 0
添加一条评论
if you're worried about overseas vendor via ebay, here's a US based vendor I've seen that has just the front glass "lens" for your nano.
note the front glass *IS* as separate piece from the actual LCD display for this iPod. see the teardown report here
I have no experience buying from above-mentioned vendor, I just have noticed their listings in the past.
这个答案有帮助吗?
得分 0
添加一条评论
Try Ebay when getting the part or amizon take the old one out and watch the i fix it video on youtube.come it hapendend to my touch and the my sisters nano
这个答案有帮助吗?
得分 0
添加一条评论
The usability is about 1000 times better than before. You flick through albums and pick songs directly. You don’t have to operate it without looking since you can clip it so many places and show the screen at any rotation. You can wear it as a watch. Arguing for a click wheel makes no sense at all.
http://www.applereviewed.net
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karen Cattell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 8,397
