跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Water Damage | No Display | Stuck in Recovery Mode
Hi Guys, I have a friend who drowned her iphone 6S! Not certain how long it was under but here are the conditions:
- No display
- The device is still recognized by iTunes
- Stuck in DFU mode.
I've tried the usual power and home button combinations but iTunes still prompting me to restore. I've also tried 'tiny umbrella' to attempt kicking it out of DFU but no luck there.
Is there any way to get it out of DFU so I can perhaps save the photos?
Would appreciate your input.
DAXimus.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'm guessing that you didn't clean out the internals before powering the device on?
The simple answer to your question is that there probably isn't any way to save the device or recover any data at this point. If you would like to give it a shot, iFixit did a great video on water damage and it shows exactly what happens when you get your phone wet.
https://www.youtube.com/watch?v=DsDpALKQ...
Chances are having the device powered on (please tell me no one plugged it in too?), fried the internals.
这个答案有帮助吗?
得分 1
6条评论:
Hey Josh, yes I cleaned the internals with alcohol as best I can with a brush and let dry but this device came to me after several attempts from the owner. With that I think the damage was already done.
Thanks for your link. I always consult Jessa Burdett's expertise but since it appeared to be in DFU I was a bit hopeful.
I don't currently have the resources to do a more through decontamination using ultrasonic means so it's gonna have to be replaced.
完成的
Jessa is the bomb!
I have a horrible record for repairing water damage and it always bums me out when people here post with it. There isn't any big trick unless you are willing to do surgery, and even then its a crapshoot.
Sorry man
完成的
You can still sell it for about 400 dollars though and get a brand new iPhone SE :)
完成的
no...no you can't
完成的
Why not? I thought a water damaged 6s can go for like 400$
完成的
显示更多的1条评论
添加一条评论
添加你的答案
DAXimus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 23
总计 8,288
