跳转到主内容
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
The LCD brightness is darker on one side after replacing?
i have just replaced the LCD on an ipad 3rd gen. I have completed the repair and now i have noticed that one side is darker in screen brightness to the other side. Why is this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
thanks Josh. i will have a look. i never use tools to disconnect cables. luckily my nails do the trick, but it maybe a screw too tight. Thanks for the info. :)
完成的
添加一条评论
1个答案
已选择的解决方案
How much darker? Can't read it dark or just annoyingly dark?
If its just a bit darker, it could be as simple as a screw or something else is stuck under the LCD causing it to look funny. If its noticeably darker, then you blew one of the backlight filters. There are 2, one for each side of the screen. Its very common to blow those filters, especially if you used metal tools to disconnect the LCD or digitizer.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 122
