跳转到主内容
2.1 speaker system from JBL with 36 watts and capacitive volume controls
5 个问题 查看全部
It keeps making a loud humming sound.
Unfortunately the JBL Spyro is making a loud humming sound that gets me a headache. No one can stand this sound so I cannot use it anymore. I already checked all the cables and everything is right here. How can I get rid of this humming?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
When I did a teardown of my JBL Spyro sub, I was pleasantly surprised with the overall build quality with one exception — the speaker cone surround.
Of all the available materials for the diaphragm surround, they chose to go with a flimsy foam that tears more easily than wet 1-ply bathroom tissue. This was the cause of my humming.
To fix the tear, I used E6000® Permanent Flexible Adhesive and a patch. I used a BAND-AID® Brand Flexible Fabric Adhesive Bandage because it was easy to apply and is engineered for flexibility. Use just enough E6000 to cover the BAND-AID*. I let the adhesive cure for at least 24 hours before testing. The results were excellent.
*Do NOT overdo it with the glue. I added extra adhesive to see if I could make it more resilient to kick-bass at maximum volume. It made the cone too heavy and stiff so it doesn’t sound as good anymore.
这个答案有帮助吗?
得分 3
添加一条评论
I just found a shop where they sell repair kits for any type of speaker. Will order those for my JBL Spot speakers and give them a try.
这个答案有帮助吗?
得分 1
1条评论:
Worked out perfectly for me. Looks and sounds like new!
完成的
添加一条评论
添加你的答案
Arianne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,174
