跳转到主内容
加入维修社区 - 创建账户
iPad Air 2 color problem
When I read the news on iPad, my iPad screen suddenly chage to this color and I don't know why. I'm using iPad Air 2, ios 9.3.3
https://drive.google.com/open?id=0BwQZhV...
Does it have any way to solve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have a problem with orange color screen (Not a yellow screen)iPad Air 2
Please tell me how to fix it
完成的
添加一条评论
4个答案
最有帮助的答案
I have the same issue. I have an iPad Air 2, IOS 10.
I wasn't able to FULLY fix it, but I got the colors back.
Go to Settings > General > Accessibility > Display
Turn 'Reduce White Point' On, then set it to 87%. Set brightness to max.
I do not think there is a possible fix unless having it checked by Apple professionals. But temporarily, this can lessen the display issues. Will use up more of your battery though.
If you were able to find a solution, can you please tell me?
这个答案有帮助吗?
得分 4
3条评论:
It needs New LCD, It is quite common on iPad Air2.
完成的
I just discovered this fix, and it set the colours back to normal mostly, then goggled it and came here. Since I just did it I don't know if the temp burn will continue
完成的
It didn't fix for me apple ipad air 2, still looks terrible for years now. Just too old.
完成的
添加一条评论
Does the screen have those distorted colors any other time or only when your reading the news? If it's doing this all the time then it's one of two things the LCD connector maybe is loose or the LCD may have been damaged.
这个答案有帮助吗?
得分 1
1条评论:
All of the time :((
完成的
添加一条评论
Hey poloniumra,
Wow, that's weird. I have only seen that on computer monitors. If I know more about it and a solution I will tell you ASAP.
这个答案有帮助吗?
得分 0
1条评论:
I heard that if it happend, just try to tapping the back of the iPad, I have do that but it did not work
完成的
添加一条评论
I had a similar problem on my ipad air 2. Cause of the problem: bad battery; after 4 years, one of the batteries in the pack start to swell (developing gas). the swollen battery put pressure at the screen, resulting in weird colors (like inverted coloring). fixed it temporary with playing with the white color setting, however this increases battery usage and I believe heats up the airpad more, potentially damaging more components. Another fix on youtube is dropping your ipad or hitting it on the back. I believe at least the latter solution would be pushing out the gas from the battery, so it is not swollen anymore. However the gas is toxic, and the battery outershell will be torn, potentially allow leaks from the battery. If you encounter this problem someone should take off the screen (very carefull to not damage it) and check the batteries for swells and if so, replace battery. Cheaper fix than replacing the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
poloniumra 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 52
总计 29,859
