跳转到主内容
The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
20 个问题 查看全部
Power Mac G4 Tower Shut Itself Down, Won't Start Now
Power Macintosh G4 500 DP (Gigabit) M7893LL/A*
Wouldn't power up a couple of months ago. Randomly one day after several weeks I hit the power button and it was fine. Have used it 4-5 times over a couple of weeks since then. Tonight after about 3-4 minutes it shut down as if the power cord had been pulled. It will not power up. I was using a browser when it happened. I know the AC cord is live, I can hear the small electrical click when the contacts make a connection with the machine. The PRAM(?) battery reads 3.7v with a meter. I removed it for 10 minutes once and then an hour once, following reset procedure to no avail. All peripherals were disconnected during attempted reset. I do not see any lit LEDs on the motherboard although I don't recall ever seeing one but I have read that maybe there is one. (A few years ago I replaced the power supply after the tower would not power up following a neighborhood power outage due to lightning. We seem to have several outages each year in this area. Just background info, don't know if there's any relation to current problem.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What is the date printed on the 3.5 volt 1/2 AA lithium battery? Where do you live?
完成的
It is a 3.6v Tadiran made in Israel. The only printing I see that might be a date is "D L G J 07 00". I live in the Nashville area in TN.
完成的
添加一条评论
1个答案
已选择的解决方案
That battery was made in July of 2000, 16 years ago. Unless you have a battery tester to how much of a charge it is retaining, it might be a good idea to replace it. You should be able to a new one for about $7.00 US. A cheap place to start. Then we can look at your power supply.
这个答案有帮助吗?
得分 1
5条评论:
As previously stated in my question the battery is reading 3.7v. I took the battery out and checked it with my Ideal model 61-746 meter set to measure DC voltage.
完成的
That's the correct voltage but delivered at what level. A battery at 5% will still give the same voltage. Download and run Coconut Battery to see where it's really at. You'll need an older version. Get version 2.6.6 here: http://www.coconut-flavour.com/coconutba...
完成的
As previously stated in my question, the computer won't power up. I can't download anything or use apps.
完成的
Spend the $7.00 so you know!
完成的
Someone on an Apple forum gave me instructions for testing the power supply with a volt meter. The battery is not part of the equation for that. I believe the power supply is not functional.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 342
