跳转到主内容
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
How to replace trigger spring?
Hi, I've got a controller that was dropped and the trigger is now loose. When I opened it up I see that the small spring that pushes the trigger back up is broken. I have a replacement spring and bar, however I can't seem to remove the old one. Anyone smarter than me out there got any tips?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
doubtful there is anyone here smarter than you, google is your friend.
完成的
添加一条评论
2个答案
最有帮助的答案
There should be a bolt through the middle, holding it in place. You can stick a needle or something small and thin in the end of it and it will come out.
这个答案有帮助吗?
得分 2
添加一条评论
bend a paperclip to push it through
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
barrypearson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 7,853
