跳转到主内容
魅族手机维修指南。
Antenna tabs broken, need hardware repair suggestion
Hi, during a dissasemble of a meizu m2 note sadly i cracked and broken two antenna tab in the the usb chargin port pcb.
So i insert the sim card and i noticed there is a X so i'm unable to connect mobile data. I already saw the possible replace (luckly is not the whole motherboard) but is divide in two part on Ebay.
So my question is: the mobile data problem could be the issues for faulty antenna tabs? Please help me i need an opinion as fast as possible.
http://imgur.com/a/BDsyk
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi to everyone, i would like to update my question and how i fixed the issues, so i fixed the issues by replacing the usb connector board (bought on a famous auction site) and after that you have to (sadly) re-assemble the complete case in order to your mobile network work fine.
The latest step is really important because in the backcase (inside) there are the antenna's flex's (the white one) otherwise you are unable to get any mobile data, so is not like the other smartphones. Hope this will help someone.
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much for helping me in this question. I have the same problem and with your help I will try to fix it. Thank you, thank you...
完成的
添加一条评论
添加你的答案
Vermillion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 746
