跳转到主内容
宏碁在1997年购买了德州仪器的移动PC部门,从此进入了笔记本电脑的世界。
Why my acer laptop wireless internet is not working?
i have a acer laptop but all of the suddan my acer laptop wireless internet is not working but all other devices are connected with router at my home . please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 23
15条评论
i would say check the wireless driver and update it http://goo.gl/GXXiB1 and make sure you have the right driver and settings
完成的
thanks i was helpful and i got my wireless working . thanks you so much
完成的
try removing the check mark also from wireless adapter for power managment checkout the wireless adapter properties settings .
完成的
after doing everything its just still not working .
完成的
now its not showing any wi fi network
完成的
显示更多的10条评论
添加一条评论
10个答案
最有帮助的答案
just reset the settings in wireless adaptor . and make sure you update the wireless driver after reset and see if any other program is not blocking the internet connection . check the wireless adaptor settings for any other help before you try reset the computer just visit acer for latest driver and manual click http://www.acer.com/ac/en/US/content/sup... and let me know if you need any other help
这个答案有帮助吗?
得分 7
2条评论:
got it fixed . thanks
完成的
Hi good evening I just loaded to my swift now and am trying to connect it to my laptop but it's saying it can be connected please why I need for an exam now?
完成的
添加一条评论
as far as i know this problem is coming with lot of windows 10 devices anyway - i did not liked windows 10 for many more reasons just follow the steps see if this helps you
reset the wireless adapter and remove the wireless driver and restart the computer after restart just go to wireless driver settings and uncheck the power management mark and update the driver see if that helps you . thanks
Update (11/04/2016)
hello everyone ,
i had a acer laptop while ago and i had this problem once . please try thease steps and see if this works and solves the problem
1- try updating the wireless driver . push window key +R at same time and you will see run box at the left bottom side of computer type ncpa.cpl and click ok
2- Here you can select your wireless adapter and go to the properties of the adapter and select the driver of the adapter and go to the driver section now click on update the driver and it will update it .
3-try removing any filter from adapter and check the firewall setting
4- if these steps do not work follow FIX Windows computer wireless problems
and please comment below to let me know if it did fixed the issue . thanks
这个答案有帮助吗?
得分 3
7条评论:
i tried almost everything but did not worked for me
完成的
thanks it helped the part after update . thanks
完成的
Thank you soooooo much! This was sooo helpful!
完成的
Tried but it didn't work our other laptop and phones connect but not this acer and a kindle
完成的
My wireless adapter stopped showing up in devices after update, its an acer aspire r11 but it came with windows ten
完成的
显示更多的2条评论
添加一条评论
check the wireless driver and settings and update the wireless driver . thanks
这个答案有帮助吗?
得分 2
3条评论:
i am also having the same issue . somehow its just not working . i don't know what should i do to solve this problem . should i just change the wireless card of my laptop . does that solve the problem
完成的
i just tried updating its still not responding and no wireless connection . now i can not see any network name or any network
完成的
how the f do you update drivers, my lovey, if you can't connect to the freaken internet!!
完成的
添加一条评论
Guys,
Even I had the same problem. Got it fixed.
If all other methods failed, All you need to do is remove the battery from behind and reinsert the battery.
You are good to go.
To remove battery in Acer, just insert a pen into the hole behind and push it to the right.
The battery will pop out.
All the Best
VJ
这个答案有帮助吗?
得分 1
添加一条评论
Suffered this problem for a couple of years, got fed up and configured the internet for ethernet cable. Now each time the wireless card packs in, just plug in the ethernet connection and for some miraculous reason unbeknown to man, the wireless switches back on each and every time.
Finally!!!!!
这个答案有帮助吗?
得分 1
添加一条评论
i am also having the same issue . but i think reset the wireless settings and checking the driver status will help for more i thing uncheck the power managment option fron driver settings
这个答案有帮助吗?
得分 0
4条评论:
thanks it worked for me
完成的
i tried reset and uncheck the power management from wireless adapter and its not working at all.
完成的
please try uninstalling and installing the wireless setting see if that works
完成的
hi i am having trouble when you log on to internet and log on again it wont hold information sent it away for repair they said it was screen problem when igot it back from repair still the same i amwaiting on answer from store where i bought it to see what they say any ideas
完成的
添加一条评论
reset the wireless driver and uninstall it and than restart the computer and get the latest driver from acer site and make sure you check the playback device settings in sound manager
这个答案有帮助吗?
得分 0
添加一条评论
1. Go to device manager .... Check the drivers installed .
2. If drivers are installed properly ...and seemingly there are no other issues, then just remove your battery, disconnect from charger wait 10 -15 secs put back battery and check.
3. Still not ? may be your wi-fi internal card connectors got unpluged usually doesn't happen.
这个答案有帮助吗?
得分 0
1条评论:
no i think you may need to reset the wireless adapter and wireless ettings and try updating the adopter again if nothing works than you might need to reset the computer
完成的
添加一条评论
Where do I find the Local Area connection adapter to enable it
这个答案有帮助吗?
得分 0
1条评论:
Hi,
If you have Win 10 installed, right click on the Windows Start button on the left side of the Taskbar and click on the Device Manager link.
When in Device Manager scroll down to Network Adapters and click on the > symbol to the left of Network Adapters to expand the list.
Then right click on the LAN network adapter entry and click on enable.
完成的
添加一条评论
https://okadtech.com/acer-nitro-5-wifi-p...
Just go and solve your problem and thanks me later
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 126,009
