跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
Wont turn on, and doesnt show that it is charging eithier
Hello,
I was playing smash 4 and i dropped it, immediately it shut down. It wont boot up or even show a sign of life, not even a signal that it is charging when i plug it in. I have no clue what happened, not sure what to do on it. Please help me with this, i would really appreciate it. This is about a new 3ds xl.
Thanks,
Jeremy
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Also have this problem.
Tested the fuses, they are OK!
Tested battery with multimter, it shows voltage...
Checked screen cracks, they not seem to be there...
what else could causing this problem ?
Should i replace the powerboard ?
Thanks!
完成的
I have the same problem. Charge light doesn't come on during charging ( voltmeter testing shows battery is being charged). Battery replaced, no change. Power adapter replaced, no change. Power plugin on motherboard resoldered, no change. Both microfuses, ok.
完成的
添加一条评论
2个答案
最有帮助的答案
Hey Jeremy B,
I think you should replace the battery. That should help!
任天堂3DS XL 电池更换
Nintendo 3DS XL Battery
Nintendo 3DS XL Battery图片
产品
$23.99
这个答案有帮助吗?
得分 1
4条评论:
if it was the battery, it would have shown that it was charging at least for a second when i plugged it in, am i right? But, it doesnt even show that.
Thanks,
Jeremy
完成的
Probably not, the battery is cheap. Try the battery first before taking too big steps.
完成的
ok, i will try that and see what happends, thanks.
完成的
Thanks for trying to help, but, it didn't work. Going to send into Nintendo for them to fix.
完成的
添加一条评论
the battery is probably loose you can test it just by trying to power the system on with out the battery and if you get the same results try to hold the battery in manually and try to power it on if you still get the same results then i guess you should get an new motherboard and try it like that when it still fails i think your whole 3ds is broken
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 527
