跳转到主内容
Repair information for the Asus VivoBook S551LB laptop. First available on Amazon in July of 2013. Model number: V551LB-DB71T.
13 个问题 查看全部
resting to factory sttings
haw can get factory setting for my asus
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If it's not an old model then you have a recovery partition, so with Asus you shut down your computer. After you turn it back on hit the F9 key right after you release the power button.
这个答案有帮助吗?
得分 1
1条评论:
Many viruses will damage the recovery partition, and it will still require a password to do the reset in windows 8 and 10. A clean install is always best
完成的
添加一条评论
Re-Install windows by getting the correct iso (make sure it is untouched, no crack or piracy) and putting it on a usb with rufus.akeo.ie and then boot from that usb by pressing esc repeatedly while booting and selecting it.
Delete all partitions when installing windows and let it create the necessary system partitions again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alrashed doura 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 394
