Replaced Screen after working initially the screen went black
Replaced Screen in IPad Mini everything was working fine. The battery was at 4% so I put it on charge and about 10 minutes later I checked it and it will not power on.
Any suggestions?
Hi Travis I take it you left it on charge for a while you can redo again to see check connections possible a faulty screen turn it on with the screen still loose in case its impeded when housed,remove battery(if possible) and try again no real way of checking as they are the devil to test unless you had same model again to swap it was old screen working at all will it still work back in again..sorry its a case of elimination which is a pain..
这个答案有帮助吗?
I opened the I pad again. And disconnected the cables, reconnected the cables, then reinstall everything. And it powered on. Thanks for your input.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 49
