跳转到主内容
加入维修社区 - 创建账户
LCD Inverter Problem or Backlight Problem
Hi,
I've a Toshiba Qsmio X500 that is dual lamp lcd inverter. The lcd screen is black it has very dim light and I can barley see the laptop is working and with the external monitor the laptop is working fine. I thought the inverter was failed and I ordered a new inverter and the problem is same. I was thinking that the lcd lamp is gone but when I use inverter tester which I've bought from ebay to test lcd lamp it is showing light on lcd but not too bright, on the right side of the lcd is more or less ok but left side is very low or dim light. As the lcd has dual lamp is it possible that one lamp is gone, if so when I connect single connector from lcd to the inverter tester it does the same only right side is bright, it doesn't matter which connector I'm connecting even if I connect both of them it is still same only on right side of the lcd is bright.
If I connect other single lamp lcd to the Toshiba Qsmio inverter the display is black so the inverter is not working and it is a working display so no doubt. I've tried both of the output from Toshiba Qsmio dual inverter and the result is same.
Is there any way that I can power the Toshiba Qsmio dual inverter and check with different working lcd or is it the problem coming from motherboard. I've checked the voltage but not sure it is the right voltage or not, I think the pin 1,2 has 18.5V and other pin doesn't have any voltage, if you need specific voltage of pins I can measure it and give you update. So if is possible to power the dual inverter without motherboard I can check the inverter is good or not. If so what is the voltage would be for the specific pins?
Please help me.. Thanks everyone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I have had the same problem for nearly 1 year on my TOSHIBA Qosmio X500, W10 Home. All expert actions and advices were ineffective. It is for sure not related to bad inverter. I had to start screen by pressing Windows button +P and Fn+F5 for several times, up to 10times. Some guy from Mexico wrote solution which is unbelievable:
In Power options<Processor power managemen<Minimum processor state: set both data(On battery and Pluged in) to 100% (mine was at 7%). The same in Maximum processor state set to 100%.
I did so. Since then, no problem any more. MIRACLE!!!! But it works 100%. Why? It does’nt matter
Joze Buh, Ljubljana, Slovenia, mail: joze.buh@gmail.com
这个答案有帮助吗?
得分 1
1条评论:
Seemed not to work. Put the whole thing away. Did a restart intending to HDMI link to the TV and check drivers. Lo and behold, both screens were live. my settings on processor state were 5%....moved to 100%. All Good. Thanks for your detailed post still useful in 2024.
Oh om a Tecra M50, SSD and Modern internal battery
完成的
添加一条评论
the inverter get 18v then make it 28v to get led working there a small led lamp if you are familiar you can make it work some kind of modification you can sold wire with 12v behind the lcd it will work
and there is lcd to led converter it work for me with toshiba model l550
you can try it
and upload the pic of the inverter
and dont forget to test the lcd spin flate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Akram Hossain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,743
