跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 个问题 查看全部
Fingerprint Sensor no longer working after screen replacement
Recently did a screen replacement on an iPad Air 2, transferred the customers TouchID button and it functions as a button.. but the Fingerprint scanner function no longer works. No damage is visible, reseated connector, options in the simply say setup failed...
Don't see any components missing or anything, just a simple single plugin for the Touch ID button.
Any clues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Just did a iPad Air 2 yesterday and didn't have any problems. I did have an issue with a iPhone 6, about 6 months ago same issue no damage, triple checked. The customer did a update that came out a month after the repair and the scanner started working again after the update. The iPad Air 2 and the iPhone 6 are the same generation. Heard other people have the same issues and a later update fixed it. I would tell the customer to see if the next update fixes the issue if not bring it back.
这个答案有帮助吗?
得分 0
1条评论:
I replaced a screen on an iPad Air 2 a couple of weeks ago and had this problem. I have been searching for solutions and am yet to find one that works. After seeing this answer I was hopeful, but it still doesn't work after the most recent update. Not really sure how an update would make a difference either. I am still hopeful, but am losing hope. Anyone have any luck with this yet?
完成的
添加一条评论
I have the same problem. I have updated and restored the ipad with no luck. The only option is to consider another LCD. I've done thousands of iphone 6, and sometimes the cable that the home button plugs into is faulty. That's a cheap and easy fix, but another Air 2 lcd is real expensive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The Stem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 1,119
