跳转到主内容
Quad Core 9 inch Android enabled Tablet, released October 2014, identified by model number ME-9Q
Why is my front facing camera not working?
Whenever I go to take a picture the camera shows a black screen. I've tried factory resetting the device with no avail. Do I need to replace the camera or is it unfix-able?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
First be sure that the lenses view isn't obstructed by any foreign objects, i.e. fingerprints, dust, etc. Also be sure that the lighting is adequate. If this doesn't help you may need get inside the tablet. When you take it apart be sure that the camera's cable is plugged in all the way; otherwise, replace the camera.
这个答案有帮助吗?
得分 0
添加一条评论
As a last before replacing the camera module, try to do a factory reset. Sometimes, more often than not, there may be a software glitch that will cause the camera module drivers to operate improperly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Justice 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 189
