跳转到主内容
Repair information for the Logitech K750 wireless solar keyboard. First available on Amazon in 2011. Model numbers: 920-002912 (Windows), 920-003472 (Mac).
12 个问题 查看全部
Changed battery but still no signs of life?
I have bought and replaced the battery with an Maxell ML2032, but the keyboard doesn't show any signs of life. There is no green or red LED in the top right corner and the keyboard is not found by the unifying software. Each of the solar panels gives about 1.5v output when tested with voltmeter and the battery itself gives just over 2.8v (the old battery has less charge and gives about 1.2v).
Is there anything else that I might be able to do to fix the keyboard, I don't want to have to replace it?
Thanks in advance for any suggestions.
Scott.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
1条评论
same here. you are not alone
完成的
添加一条评论
3个答案
最有帮助的答案
Turn the battery over. With the keyboard right side up you should see the smaller negative side up.
这个答案有帮助吗?
得分 4
1条评论:
Just for clarification, the correct position of the battery is shown in the step 5 of how to change the battery: Logitech K750 键盘电池更换
完成的
添加一条评论
You could have a look at the power (On Off) switch. On my K750, this switch is starting to fail causing symptoms like you describe.
这个答案有帮助吗?
得分 3
2条评论:
I have this problem (Logitech has put obsolescence on the switch too to kill the keyboard). Curiously, the switch is always "on" and drain the battery even if we do not use it.
Have you solve the problem ? How ?
Thanks.
完成的
Turn the battery over before anything else
完成的
添加一条评论
Hi Scott, my guess would be that the logic board may need to be replaced OR a cable could have come dis-connected from the board or the battery itself. I suggest trying to re-install the new battery.
这个答案有帮助吗?
得分 1
5条评论:
seems reinstall makes no difference. for me zero power even with new battery. how to fix worn power switch?
完成的
I have two of theses, both went down within the last month, I changed ther ML2032 battery in both, still no life, Logitech are holding something back from us regarding the answer!
完成的
完成的
Turning battery over was the game changer, installed replacement wrong and then just put old one back in (battery goes in opposite of what you'd think). Also used a hack of turning off keyboard, holding CAPS LOCK down and pressing buttons for 5 seconds and then turning keyboard back while under direct light.... .those 2 things revived my keyboard.
完成的
Larry Jackson and Rob Lazott, you both just made my K750 keyboard go from dead to back to life! Thanks so much for the tips on turning over the battery AND the CAPS LOCK trick. I'm back to seeing green! :D
完成的
添加一条评论
添加你的答案
scott adam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 91
总计 6,462
