跳转到主内容
加入维修社区 - 创建账户
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
Replaced digitizer not recognizing touch
I recently replaced the digitizer on my Apple Watch but I did not replace the LCD. I followed multiple guides to make sure every thing was going correctly. I ordered one digitizer/glass unit from Amazon and it did not work. I figured it was defective so I ordered one from iFixit, who I trusted more. It did not recognize my touch either. The only thing I didn't do was apply LOCA glue because it wasn't needed as far as I was concerned. Any help with this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
I repaired an apple watch myself, but I used a full digitizer/LCD unit.
Although you probably tried this already, when I firstly reassembled my apple watch, touch wasn't working either, but only because the connector wasn't connected properly, although I was convinced I had it connected correctly. Maybe checking this could help you out.
这个答案有帮助吗?
得分 1
1条评论:
@klausibert which was the connector which was not connected properly? The one linking on the top left of the watch from which the display ribbon cables start?
完成的
添加一条评论
I have the same issue and ordered a new digitizer to replace it, Did you ever find a fix? Apple wants to charge $200
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 18
总计 294
