跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
WiFi cannot turned on
Hi,
Got an iPad Air send in by a customer few days ago.
Glass is slightly broken and WiFi cannot be turned on.
Biggest issue is the WiFi.
Tried every possible solution i could find on the web, but unfortunately nothing seem to help. Replaced the WiFi antenna, problem not solved. Ordered a 2nd WiFi antenna and put it in, doesnt work either.
Anyone had the issue / knows a solution?
Tried to reset network settings, resetted the intire ipad, ect ect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hey Seppe de Zutter,
I think the Wi-Fi Logic Board is damaged. You should replace that.
iPad Air Wi-Fi Logic Board
Replace a logic board compatible with the WiFi model A1474 1st Gen iPad Air tablet. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
$99.99
这个答案有帮助吗?
得分 1
3条评论:
Hi Stijn,
Thanks for the reply, gonna try it.
完成的
Why not replace the Wifi ic chip on the logic board? This solves the greyed out, can't enable Wifi issue.
完成的
Yes please! don't spend that much money buying a whole board. try first with the wifi IC . It's the 339S0213 IC also suitable for Ipad mini 2.
Indeed you will need to know somebody who has the abilty in micro soldering as it's a trick job to perform. Better: the first thing to do before buying this IC and changing it, try to reflow the chip actually in place on the motherboard with a hot air station. It could be one ore more solder point that are not ok. I succeeded permanently with this method on an Ipad 4 wifi with the same issue as your. This said it can also be an issue with the chip and also reflowing can revive it for a while (in that case it won't be permanent). But at least you will know the origin of the issue and what to do. ;)
完成的
添加一条评论
添加你的答案
Seppe de Zutter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 450
